I want to backup Memento but the menu on that thing is quite large, 951 MB to be exact. I was going to use dvdrebuilder with cce to reencode the flick but rebuilder doesnt support reencoding the menu just yet.
I know I can use dvdshrink to transcode the menu and leave the rest of the movie untouched and then move on the dvd-rb. But the quality of shrink really sucks compated to cce and I don't want that huge of a difference.
Another option is using NuMenu4U, but I don't have Scenarist and that proggy seems like it takes a bit of work to learn how to use it correctly.
Does anyone know what another option is?
Boy do I love my avatar!
Have you tried Shrink 3.2 with AEC ? The quality, while still not CCE, is substantially improved over the older versions. Given the size of the menu, you aren't going to get it much smaller than 500MB without doing a lot of damage, and this is still a hefty chunk out of the movie. If it was me, I'd ditch a menu that large - it's not worth it.
Read my blog here.
AEC is a new enhacement feature to the transcoding that improves quality substantially over the older versions of Shrink. You need DVD Shrink 3.2.x to get it.
The menu may be cool, but is it worth 10% (or more) of your movie space ?Read my blog here.
Hi.
tsantsa, why don't you make two backups?
A movie-only one, and a full-disc one.
When you fancy watching the movie, play the 1st backup.
When you fancy watching/playing with the menu, use the 2nd.
On a serious note, how much would the movie have to be compressed by if you did a full-disc backup? -
tsantsa
Look at your menu structure. Sometimes it is composed by more than one menus, one for each language.
If so, you have two options:
- Strip the unneeded menus (the languages you do not need) using IFOEdit (look for the guides for how)
- Compress with Shrink to the maximun the unneede menus, set the menu you want to keek to No compression or above 80% to keep the quality. You can do this step twice to get the maximum compression for the unneeded menuNewbie to DVD backup
Reencode
By mentme33 in forum Newbie / General discussionsReplies: 9Last Post: 17th Dec 2010, 13:08 -
SVCD2DVD when going to DVDShrink & DVDShrink Re-Author Problems in Vist
By pcandmac2006 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 23rd Jan 2009, 19:33 -
DVDs Copied with my laptop dvdshrink act weird, missing chptrs, menus, etc
By fred_dj in forum DVD RippingReplies: 5Last Post: 17th Dec 2008, 09:08 -
DivX reencode
By Ogilvy in forum LinuxReplies: 1Last Post: 3rd Jul 2008, 14:17 -
Menus on DL-DVDs created with DVDShrink...
By takearushfan in forum Authoring (DVD)Replies: 2Last Post: 12th Sep 2007, 01:48
