Results 1 to 14 of 14
  1. Hey, I've got an mpeg recorded from tv with some pretty bad noise in it. I'm not sure exactly how to clean it up. I've tried dynamic noise reduction and 2d cleaner in virtualdub, but neither worked. Does anyone know which filter I can use with vitualdub, avisynth, something else? Here's a screenshot of what I'm dealing with. The dots jump around pretty fast, but stay localized to the bands that are evident. Also, the bands move up the screen, keeping the same distance from each other, and eventually appear out of the bottom again.
    Australia
    Haven't tried it myself but the example is impressive..
    Try the 'Spot Remover' filter here -> http://konstant.freeshell.org/
    Let us know if it does the job.
  3. Thanks for the suggestion, but unfortunately spotremover did not work.
  4. Note: The jpeg doesnt really show the dots well. They are actually much sharper, and are pure white.
  5. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    I am surprised that Spot Remover didn't work. The other filter that often works for me is Temporal Cleaner (read about here - includes download link http://www.undercut.org/articles/temporalfilter.html ), although this may be a big ask for it. It is the fastest quality noise remover I've found.
    Read my blog here.
  6. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Maybe convolution3D ?
    If in doubt, Google it.
    I've seen that error. THe dots may be too fast and too small for filters to catch. But good luck, and don't give up.
  8. The Old One SatStorm's Avatar
    Hellas (Greece), E.U.
    I never manage to clear those dots like yours, without heavy filtering...
    Deinterlace (unfolge), use "frame merger" at a higher value and deinterlace (folge) again.
    That might help a bit...
    All the other solutions I can think of, are "temporal" (time axis based) filters, that distorts a lot the motion...
    La Linea by Osvaldo Cavandoli
    You wouldn't - most decent filters are of the "switching" type, ie. if the difference between the filter output and the input pixel is above a certain threshold then the filter switches itself out, restoring the unfiltered pixel. If you raise the threshold high enough to remove these high intensity spots then it will introduce a lot of distortion elsewhere in the picture...
    Caught between a rock and a hard place... A good temporal filter would be of the switching type, hence it would not blur motion noticeably... but it would also not remove these spots, since the prediction errors would again be too high.
    Incidentally, this doesn't look like normal analog noise to me. It looks like electrical interference, caused either by poor quality capture card electronics, or poor quality unshielded video cable passing close to some interference source.
  10. Originally Posted by mpack
    hmmm, looks like what I see on the TV when the vacuum is running. Very interesting noise pattern.
  11. The Old One SatStorm's Avatar
    This kind of noise is electrical interference. That's for sure. I know about it, because 18 years ago, terrestrial "transmissions" with that kind of noise, use to be usual, when some local stations here in Hellas broadcast from analogue satellite feeds. Most of the reasons was stupid ones, like all the electrical interference of that kind.
    MTV Europe use to transmit with such "noise" for more than a year here, when it had terrestrial distribution in Hellas.
    Beause I have many tapes from that period, with rare music videos from late 80s early 90s, I had to deal with that kind of noise. I never manage to "clear" the picture from it, but I manage to make it look less, with the combination I suggested. And without move distortion (a typical problem that occurs with the Dynamic Noise Reduction filter at higher values, or the framemerger one... )
  12. Member LSchafroth's Avatar
    Dec 2002
    Originally Posted by Wilbert
    Is there a way to use these in Virtualdub? I'm not sure if I would prefer pulling all my teeth or use Avisynth?
    LS
  13. Member Soopafresh's Avatar
    Jan 2004
    Learning AviSynth is a path to enlightenment...
    Post a <2mb clip up here and let's see if we can help
