Results 1 to 22 of 22
  1. Anonymous
    Guest
    I had to reformat my xp pro os. Reinstalled everything. Now my browser causes noises when I scroll,etc.Any ideas?
    edit-right speaker only is the problem
  2. Member 888888's Avatar
    Jan 2004
    Turdistan
    Sound drivers might be the problem. I remember I used to have noises on my old computer when I scrolled. Don't remember exactly how I fixed it but I think I updated the sound card or mouse drivers.
  3. Member glockjs's Avatar
    Feb 2004
    the freakin desert
    i have that too. freaked me out the first time i really heard it. my solution....winamp, turn the music up and you cant hear the noise anymore
  4. I have that to, I have a wireless mouse I think it's because I have 2 pcs and speakers and things plugged into all power bars into the same outlet or something with the connections in the back, but I'm to lazy to really check it out I just turn the sound off.
    Oh yeah I think it's just my cheap set of speakers,
  5. Member ViRaL1's Avatar
    Jan 2004
    Making the Rounds
    Mouse muffler?
    Nothing can stop me now, 'cause I don't care anymore.
    Australia
    This must be a 'feature' of XP - I have that prob also, but I tracked it down to being interference through the CD audio - always ON. I just mute the CD audio option in windows 'Volume Control' and all is quiet.
    Mouse muffler?
    I've got to get one of those! The little bugger just chatters away all day - won't shut-up.
  7. Originally Posted by Dr.Gee
    Had that happen once. I muted something in the sound control panel and that fixed it. I think it was the same as what bunyip said
  8. I hear it too, but only when I wear my headphones. Sort of a high-ish pitched "zzzzzzz"?
    I use a Microsoft cordless mouse.
  9. [url=http]text[/url] Denvers Dawgs's Avatar
    Feb 2003
    Right Behind You. . .
    If I have my speakers on with no music, when I hit back/forward button there is a click. Also happens when I go to a new page. Why? and how do I stop?
    What We Do In Life, Echoes In Eternity....
  10. Banned
    Sep 2004
    Inner Circle of Thought
    I don't have that problem.
    I use firefox.
  11. Member lowlow42's Avatar
    Oct 2002
    SW Florida
    I also have that problem. When listening to audio in WMP, if I scroll in IE, the music skips. Same thing happens when I type. What is it?
    "The statement below is True,
    The statement above is False"
  12. Banned
    Sep 2004
    Use mozilla firefox and you should not have that problem.
  13. Member lowlow42's Avatar
    Oct 2002
    SW Florida
    Oh ok, I've been meaning to try that out. Does it have all the same features as IE?
  14. It's a driver problem not IE or its not setup correctly, Mozilla is not that great
  15. Member lowlow42's Avatar
    Oct 2002
    SW Florida
    Hmmm... I just switched to a new soundcard (M-Audio Audiophile 24/96), and got the newest drivers.
  16. Banned
    Sep 2004
    Firefox not mozilla.
    Firefox is wayyyyyyyyyyy better than internet exploder.
  17. Heresy!
    Mozilla is great. Firefox is even better. IE is only better in ONE way compared to Firefox... you don't have to install it.
    Regards.
    Michael Tam
    w: Morsels of Evidence
  18. Originally Posted by vitualis
    Heresy!
    Regards.
    It also has a pretty "windows logo" in the top right corner
  19. Member lowlow42's Avatar
    Oct 2002
    SW Florida
    Well, Firefox has all the options/features of IE, correct?
  20. Just about.
    The only thing is doesn't have is support for ActiveX. Some people would consider this a "feature" though...
    Regards.
    Michael Tam
  21. Member lowlow42's Avatar
    Oct 2002
    SW Florida
    Is there any way of adding some sort of plug-in for it? Or something similar?
  22. Master of Time & Space Capmaster's Avatar
    Feb 2004
    Denver, CO United States
    Yes. I need that to interface with my work network when I telecommute and use Remote Desktop to access my work PC.
