IM TRYING TO CONVERT A DIVX FILE TO A VCD BUT IT KEEP STOPING HALF WAY THROUGHT SAYING STREAMLOAD ERROR,SO BALDRICK RECOMMENDED USING VIRTUALDUB SO I TRYED THAT AND I GET TO THE PART WHEN I USE THE DUMMY FILE IN MY TMPGENC ENCODER AND IT KEEPS SAYING (UNSUPPORTED)ANYONE HAVE ANY SUGGESTIONS THANKS IN ADVANCE
Shizzzon-
Unsupported means you do not have the Directshow multimedia filter priority set to 5. Set it to 5
Make sure you have DivX 4.2 codec and smr patch
TTempsmooth Help Needed
By VideoFanatic in forum RestorationReplies: 43Last Post: 5th Dec 2011, 00:15 -
Some help needed with multiAVCHD
By VOYAGER2009 in forum Authoring (DVD)Replies: 6Last Post: 20th Jul 2011, 12:19 -
[ HELP NEEDED ] BD-ROM to BD-R 25 with BDRebuilder: how much CPU is needed?
By Tyrexionibus in forum Blu-ray RippingReplies: 1Last Post: 28th Oct 2009, 13:27 -
Filters needed
By demonwarrior in forum Newbie / General discussionsReplies: 14Last Post: 9th Jul 2008, 08:06 -
Memory upgrade needed for TMPGENC DVD Author 3, advice needed
By Caned_and_Able in forum ComputerReplies: 8Last Post: 31st Jul 2007, 19:30
