Hi,
I have a Pinnacle VCD capture card.
I am trying to capture video footage from my Sony Digital 8 camera though an S-plug. When I attempted to perform capture, the system only offer me the highest resolution of 352x-288
Questions:
(1) The limitation of the highest offered resolution is due to the capture card? or my Video Camera? or the software?
Thanks in advance.
Regards,
anon
What is the model # for the capture card?
You have Digital 8 - Why not get a firewire card.
Typically the card will limit the resolution.
If you are using s-video then try using Virtual Dub to capture and use 'custom settings'
Virtual Dub will currently NOT work with Digital Video -
Definitely get a Firewire/1394 card. Your video is already digitized and compressed in the Digital8 camera at 720x480 30fps at about 5:1 compression. This gives you a good high quality source. The file sizes will be around 3.6MB per second of video. When you "capture" via Firewire its really more like a file transfer.
You will lose quality if you output s-video from the camera and recompress it with an analog capture card. Just capture the DV format AVI files from the Digital8 camera via Firewireand edit with a DV compatible program, then encode to MPEG for VCD/SVCD with TMPGEnc or other encoder. -
Thank you all for your input. Much appreciated.
Will check out hte Firewire card. Cheers!
Regards,
anon
videocast osprey capture resolution
By jaybird in forum Capturing and VCRReplies: 0Last Post: 27th Apr 2009, 23:29 -
Force custom resolution for TV out in CLONE mode for DV Capture ?
By TheParadoX in forum Capturing and VCRReplies: 4Last Post: 6th Oct 2008, 20:00 -
tv tuner/analog capture resolution problem
By cooldude859 in forum Capturing and VCRReplies: 4Last Post: 13th Dec 2007, 02:16 -
Capture Hi8 using what resolution?
By chrishallowell in forum Capturing and VCRReplies: 2Last Post: 3rd Oct 2007, 12:57 -
capture resolution
By stompinne in forum Newbie / General discussionsReplies: 1Last Post: 24th Jul 2007, 15:45
