I'm a DVD ripping newbie
I have a new iMac G5 with a superdrive. I coppied several scenes (.VOB files) of a movie on my harddrive, and burned them on a blank DVD. The scenes play fine on my Mac, but the DVD will not work in my home DVD player![]()
How do I burn (rip?) scenes from a commerical DVD on a blank DVD, and have it work on my home DVD player?
well to just do a scene or two it requires some work
basically you have to rip them over, and then reauthor them as a new dvd
you can do this by demuxing [drag drop the .vob onto bbdemux] and then take the resulting .m2v and .ac3 into sizzle to compile a new dvd image to burn
thats if you want them just as they are
if you want to edit out sections that becomes more complicated
typically we backup the entire disk rather than just parts of the movie itself -
http://thegoods.ath.cx/~hmason/sizzle/ - sizzle
http://sourceforge.net/projects/macbbdemux - bbdemux
its fairly easy, just follow my tutoria [found by clicking my signature link]l as if you had svcd/vcd using m2v and .ac3
will .vob files alone play in a home dvd player?
By vincy in forum Newbie / General discussionsReplies: 7Last Post: 4th Feb 2012, 05:04 -
Play MKV file on Home DVD Player
By ladkvayo in forum DVD & Blu-ray PlayersReplies: 7Last Post: 14th Apr 2011, 06:42 -
How do convert Divx files to play on my DVD player?
By Solehawk in forum Authoring (DVD)Replies: 1Last Post: 29th Jan 2010, 19:37 -
i got an dvd9 movie and it couldnt play on my home dvd player
By techworld in forum Newbie / General discussionsReplies: 1Last Post: 6th Oct 2007, 05:57 -
Downloaded VOB, BUP IFO files won't play in dvd player
By COOPERMAN100 in forum Newbie / General discussionsReplies: 5Last Post: 28th Aug 2007, 05:31
