Results 1 to 9 of 9
    Sep 2003
    USA, MN
    Just what the topic say's
    Also what's the difference in the Newcastle and Clawhammer
  2. Banned
    Sep 2004
    Inner Circle of Thought
    http://forums.amd.com/index.php?s=37fe4bece4f1c0300bbeb2c892d4f1fd&showtopic=25998&st=0&#
    Click on this link and you will find out the difference.
    I believe the newest athlon 64 is the 3000+
    Sep 2003
    USA, MN
    Wouldn't this one be better than a 3000+
    AMD Athlon 64 3400+ Clawhammer Processor
    2.2GHz, 1MB, 800MHz FSB, Socket 754
    Or this one, but it has less cache than the Clawhammer
    AMD Athlon 64 3400+ Newcastle Processor
    2.4GHz, 512kB, 1600MHz HTT, Socket 754
  4. Banned
    Sep 2004
    From my understanding, the clawhammer became the Opteron processor which is usually used in servers and is way more expensive.
    The athlon643000+ is basically an fx chip that has been dumbed down a little.
    The major difference is price
    Check out this link
    http://techreport.com/reviews/2004q1/athlon64-3000/index.x?pg=1
    Sep 2003
    USA, MN
    the prices I came across were not that bad
    3000+ $160
    3400+ newcastle $233
    3400+ clawhammer $238
  6. Member zzyzzx's Avatar
    Baltimore, MD USA
    About how fast of a processor do you need to do video capture anyway?
  7. Master of Time & Space Capmaster's Avatar
    Feb 2004
    Denver, CO United States
    Many capture cards say 450 MHz P3 minimum
  8. Member shelbyGT's Avatar
    Oct 2003
    Kansas City, KS
    I had a 650 MHz P3 ... and now I have an AMD 3000+ ... need I say more?
