  1. I've been playing with this for a while and can't seem to figure it out. I'm as newbie as you get. Here is what I have. I'm using a Video capture device that captures video and audio through my usb2.0 port off my video camera. I've captured the video in mpeg2 format. Now I'm using NeroExpress to try to burn it to a dvd that I can watch in my dvd player.
    I can't seem to get it to find the file. Can you burn mpeg2 format to dvd or do you have to convert it somehow?
    I also have unlead 7 I can capture from my video camera to dvd format, but I can't get the audio to work.
    thanks for the help
    Apr 2002
    The State of Frustration
    When capturing to DVD format, make sure the audio is set at 48000.
    Hello.
  3. Well now I can't get neroexpress to reconize my dvd format files.
    Apr 2002
    Run the DVD files through normal Nero.
    Hello.
  5. MPEG2 files are not necessarily DVD compatible. Try the "what is" section to the left.
    Identifying the USB capture device would allow others with the same hardware to possibly identify a problem they may have already experienced and solved.
  6. The capture device is a XTV2.0 and it came with Unlead Video studio
    Here is a link to the one I bought. I still can't figure it out. I'm learning alot reading the board though.
    http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=11725&item=5727043631&rd=1
