  1. Where on this website may I go to download software so that I may burn movies to a CD-R using my CD burner? I would like to play the movie in my DVD player.
    I am seeking software that I would not have to purchase. I have heard that MPEG-4 software works. Is that true? Do you provide MPEG-4 on videohelp.com ?
    Please steer me into the right direction.
    if your dvd player supports divx,xvid
    https://www.videohelp.com/tools?s=30#30
    if not you must make vcd or svcd on cdr/w
    https://www.videohelp.com/tools?s=20#20
  3. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Eazy VCD, and the guide here. If you wish to put the entire movie on 1 CD, try the guide here.Very very simple indeed.
    If in doubt, Google it.
