Hi all,
Downloaded the Beta version last night. Did a conversion from my huge AVI collection through the program and it worked a treat. Defiantly better than the way I used to convert AVI's.
One small thing can the program window be done so it can be resized. At the moment the machine its on monitor is old and small screen so difficult to work with easily.
Just wondering how do I install it on my other computer to use, do I have to install the other registered version first then the new one? is that okay to do? Would remove it from the older machine once I was sure it was working okay.
Thanks for a brilliant program.
Gerry
Thanks.
That is the way to do it. Install v1.5 first on the new PC. Then do what you did on the old PC....SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Beta? what is it
By Stephanee in forum ComputerReplies: 3Last Post: 5th Nov 2008, 09:58 -
DVDFab 3.1.4.5 Beta
By devilcoelhodog in forum Latest Video NewsReplies: 0Last Post: 15th Jul 2007, 01:42 -
Beta 2.5 download?
By hordak in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 3rd Jun 2007, 04:59 -
svcdvd2dvd 2.5 beta
By bighun in forum SVCD2DVD & VOB2MPGReplies: 24Last Post: 13th May 2007, 02:46 -
Beta 2.5 first impressions
By mesaboogieman in forum SVCD2DVD & VOB2MPGReplies: 0Last Post: 4th May 2007, 18:25
