Does the core voltage automatically change according to processors needs?
my current cpu only requires 1.5v and motherboard monitor shows a steady 1.47v. Now my new cpu will require 1.65v. will the bios detect this and auto adjust?? I cant manually change my voltage in my bios. any help will be appreciated.
You should not need to do anything. If the processor is is supported by the motherboard, then the motherboard will read the vID pin (Voltage ID) and set the appropriate vcore value.
BD Rebuilder question about core optimization
By saltyjd1 in forum Blu-ray RippingReplies: 5Last Post: 21st Feb 2010, 04:26 -
Computer Temperature/Voltage monitoring questions (Appz question)
By Hank Kinsley in forum ComputerReplies: 7Last Post: 10th Dec 2008, 17:04 -
Intel Core 2 Quad 9550 or Core 2 Duo 8600 for games...
By retroborg in forum ComputerReplies: 11Last Post: 11th Oct 2008, 22:23 -
Intel Slashes Quad-core, Dual-core Processor Prices
By louv68 in forum Latest Video NewsReplies: 0Last Post: 22nd Apr 2008, 19:14 -
AMD 4200+ Single Core to Dual-Core Upgrade Issue...
By Bodyslide in forum ComputerReplies: 7Last Post: 30th Nov 2007, 16:45
