Im wanting to extract audio from some dvds.
What is the easiste way to go about this for an imcompetent fool such as myself?
Results 1 to 11 of 11
Hello,
Check in the tools section under dvd rippers:
https://www.videohelp.com/tools?s=7#7
There are several listed.
I would recommend a two step process.
Rip the DVD with DVDDecrypter or SmartRipper setting it to produce a new VOB file split at 9Gb (ensure the whole video is on a single VOB).
Open that with VirtualDUB mod. Select Audio-->full processing mode
If you want to make audio at CD resolution, also Select Audio-->Conversion and set 44100Hz instead of the source 48000Hz.
Select File-->Save WAV and save the audio to a file.The more I learn, the more I come to realize how little it is I know. -
DVD Audio Ripper - Nice and simple.
/Mats -
Can't DVDDecrypter and Smartripper, rip to elementary streams as well. And just convert that to wav? Never tried other tools, nor have I used DVDdecrypter or smartripper to do this.
Blah, blah, blah -
...in short, there are more ways to strip the audio out of a VOB than there are ways to skin a cat.
/Mats
two films, both supposedly 25 fps, but audio tracks don't match?
By cinesimon in forum Video ConversionReplies: 4Last Post: 13th Apr 2011, 23:10 -
HOW do I extract 1 audio track from a .ts / .m2ts with 4 audio tracks?!
By elgy in forum DVB / IPTVReplies: 25Last Post: 24th Jan 2011, 00:28 -
DVD - Mix Audio from two captures? What is the simplest solution?
By ChasePlace in forum Newbie / General discussionsReplies: 0Last Post: 29th Dec 2010, 12:26 -
Simplest and fastest way to compress LPCM audio to fit on DVD5
By kurbads in forum User guidesReplies: 5Last Post: 18th Sep 2008, 04:15 -
Simplest way to convert and join avi's with different audio streams??
By Lolipop Jones in forum Newbie / General discussionsReplies: 2Last Post: 15th May 2008, 12:25
