Hi,
I have a couple of videos for which there is no soundtrack available. I can capture the music, but there are voices in a couple of spots. Is there a way to either capture the music without the voice? Or, is there a way to edit out the voice? Is the voice recorded separately from the music?
Thanks in advance!
Alf
Hello,
Is the movie in 5.1 surround sound??? If so then you can use besweet to extract the 6 seperate channels and recreate just the music.
If it's stereo only it will be much harder. You could load it into a sound editor and TRY to remove the voices but chances are you'll just degrade the quality of the music.
Wow, talk about a quick reply!
I'm not sure about the sound. These are older movies ("Man With One Red Shoe", "Her Alibi"), and I'm at work so I can't check.
Thanks!
Alf
PS - Coincidentally, I was just over at imdb looking at the Return Of The Jedi message board, Yoda313. -
Both of those are older films, and probably didn't have more than stereo mixes to begin with. Even if they now have 5.1 mixes, you will probably find dialogue stretching across the front speakers as well as the centre channel.
If you have an audio editor that supports DirectX plugins, I would suggest Vocal Remover from AnalogX (freeware). Load up the front L/R channels and give it a whirl.Read my blog here.
Do do I keep the voice and soundeffects but strip out the music on a DVD?
By mbeaumont in forum Newbie / General discussionsReplies: 0Last Post: 12th Feb 2010, 16:15 -
Music Play Over Voice Separation Info Please?
By Teac23 in forum RestorationReplies: 1Last Post: 2nd Feb 2010, 07:23 -
Extracting music from foreign language audio soundtrack
By joshstephen in forum Newbie / General discussionsReplies: 2Last Post: 8th Dec 2008, 10:06 -
voice and music recorder
By zoobie in forum AudioReplies: 9Last Post: 17th Mar 2008, 10:51 -
How Can I Separate DVD Music & Commentary's Voice?
By Aaron1927 in forum AudioReplies: 5Last Post: 10th Aug 2007, 17:28
