I know this has been addressed on and off in this forum, but i was curious about a few things that i'm trying to get a fix on:
1. My understanding is that the Quick Presets simply ENTER information into the gui , is this correct? In other words - There is nothing "special" about them per se, they merely enter bitrates, frame sizes, audio codecs, etc - all things you can enter manually.
2. The differences between DVD-lo and KDVD, is simply a lower bit rate on the latter (1800 kbit/s -vs- 2300), so what makes KDVD a special format? Why would a dvd player play one and not the other?
Erik
2. For Q Matrix in Options, DVD-lo uses the Standard setting, while KDVD uses the kvcd setting -- which uses kvcd.net "Notch" Quantization Matrix, allowing for 16% average bitrate reduction in VBR mode.
x264 Presets and archiving
By Virnec in forum Video ConversionReplies: 5Last Post: 12th Mar 2010, 18:37 -
presets for Staxrip
By greendesert in forum Video ConversionReplies: 0Last Post: 7th Jul 2009, 11:06 -
Sorenson Squeeze 5: Presets
By kr236rk in forum Video ConversionReplies: 1Last Post: 27th Oct 2008, 08:56 -
Vegas 8 - Saving presets somehow?
By sdsumike619 in forum Authoring (DVD)Replies: 1Last Post: 20th Oct 2008, 01:11 -
Right Presets ? And how to encode ?
By macmithos in forum MacReplies: 1Last Post: 27th Aug 2008, 15:30
