Ok, I have 2,013 jpg files in one folder, able to recover a chunk of them. I think all of the photos are there, but a portion of them are completely black when I click on them, like they are erased. The files are there, but the pictures themselves are blacked out, any ideas? Is there a way I could possibly restore the photos that are blacked out? Thanks!
I'm assuming you did a file recovery to get these photos? Most likely they are corrupted and are unrecoverable. In other words part or most of the data for the photo was overwritten.
Those file recovery programs can restore partial files which is probably what you have. Did you happen to notice if there was any other copies. You can sometimes recover many copies of the same file if it was opened and saved a lot. -
Try opening the files in several different imaging programs, such as Paint Shop Pro, etc. before you consider the files as a lost cause. I wouldn't be suprised if they are still viewable with something.
BlackMagic 3.6.2 A new firmware update and new problem
By soat in forum Capturing and VCRReplies: 0Last Post: 10th May 2010, 17:44 -
Windows Update Problem
By bevills1 in forum ComputerReplies: 17Last Post: 12th Jun 2009, 13:01 -
Problem Printing DVD Case Insert
By boofer in forum MediaReplies: 7Last Post: 30th Jan 2009, 23:41 -
External case - 3.5 or 5.25 case....
By kenmo in forum ComputerReplies: 3Last Post: 2nd Jan 2009, 16:54 -
Win98 update problem
By bevills1 in forum ComputerReplies: 22Last Post: 7th Jun 2007, 15:36
