Hello,
I've been searching for about half an hour now for WHITE standard (single DVD) case size, triple DVD cases. I'll keep searching, but I figured I'd give a post a shot to see if anyone can help me out. Thank you.
Hello,
If your asking about a dvd case that will hold three discs in one case a friend got me one of those. I'll email him and ask where he got them. I'll post back when I get an answer.
Good luck
It's a bit more specific than that. It not only has to hold three disks, but it has to be white, and it has to be the same size as a standard single DVD case. If the box your friend got you qualifies, it'll make my day =)Originally Posted by yoda313
www.blankmedia.ca has white quads. I know you are asking for triple, but maybe this will do in a bind?
hey
try this out, I've found thi site to be pretty useful.
http://www.shop4tech.com/item2540.htmlscratch the surface off a cynic - you will find a disillusioned idealist. -
I've seen several places online that have triple-disc cases, but the only one I know of that has them in white is Sleeve City.
However -- I haven't seen any triple-disc cases, of any color, which are exactly the same size as a single-disc case. Double-disc cases, yes, but every triple I've seen has a twice-as-wide spine as a standard single case. I can't even see there being room for three discs in a standard-width case... -
Thank you all for replying, tdan is the winner for now though. I was looking for triples (hopefully with that swing sheet type format), but this will certainly have to do. Solar, check out tdan's and DVD_NDN's links to see how the cases are formatted.
Erg... one disc mounted on top of the other so that the top surface of one is within a hairsbreadth of rubbing against the other one, and arranged so you pretty much have to remove the top disc to get to the bottom one?
I suppose it's a creative solution, but I sure as hell wouldn't package my DVD's that way... I'll stick with the double-wide AlphaPaks, thanks.
Software ideas for full size DVD case sleeve printing please.
By EagleW in forum MediaReplies: 3Last Post: 29th Apr 2010, 02:15 -
Standard quality/size for MPEG (*.mpg) videos?
By Ashman01 in forum Video ConversionReplies: 3Last Post: 22nd Feb 2009, 19:55 -
Turn many small video DVDs to one standard size DVD
By bryankendall in forum Newbie / General discussionsReplies: 3Last Post: 30th Mar 2008, 18:57 -
All video types to standard size / format?
By fuzzyvideomunster in forum Video ConversionReplies: 2Last Post: 3rd Jul 2007, 11:50 -
what is the standard size or need to resize background
By leinan in forum Newbie / General discussionsReplies: 4Last Post: 6th Jun 2007, 14:24
