I keep getting this error:
SVCD2DVD.exe - Common Language Runtime Debugging Services
Application has generated an exception that could not be handled
Process id=0x688 (1672), Thread id=0x678 (1656).
Click OK to terminate the application
click cancel to debug the application
OK Cancael
I want to die in my sleep like my grandfather...not screaming and yelling like the passengers in his car.
This is the rest of the error:
Type: System.IO.FileNotFoundException
Source: System.Windows.Forms
Message: The specified module could not be found.
InnerException:
StackTrace: at System.Windows.Forms.UnsafeNativeMethods.CoCreateI nstance(Guid& clsid, Object punkOuter, Int32 context, Guid& iid)
at System.Windows.Forms.AxHost.CreateWithoutLicense()
at System.Windows.Forms.AxHost.CreateWithLicense(Stri ng license)
at System.Windows.Forms.AxHost.CreateInstance()
at System.Windows.Forms.AxHost.GetOcxCreate()
at System.Windows.Forms.AxHost.TransitionUpTo(Int32 state)
at System.Windows.Forms.AxHost.CreateHandle()
at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
at System.Windows.Forms.AxHost.EndInit()
at SVCD2DVD.2f5590cb48bb0c53.85601834555fb7d5()
at SVCD2DVD.2f5590cb48bb0c53..ctor()
at SVCD2DVD.2f5590cb48bb0c53.c447809891322395(String[] ce8d8c7e3c2c2426)I want to die in my sleep like my grandfather...not screaming and yelling like the passengers in his car. -
OK,
I got SVCD2DVD V2 working, but now I can't seem to get my machine license (site is not sending it?). I got my reg file, but can't seem to get past the machine license page.I want to die in my sleep like my grandfather...not screaming and yelling like the passengers in his car. -
You need to use the v1.5 registration.:
Registration
You will be using the registration code from your copy of SVCD2DVD v1.5. If you used the registration wizard for v1.5 there should be a file: “C:\Program Files\BadgerSoft\SVCD2DVD\machine license.txt”. If this is not the case please ensure you have the latest build of v1.5 and re-register with the wizard.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
can someone pls pm me a link for svcd2dvd 2 beta (not the official site) as for some reaon since i reinstalled windows xp i can not get into the official site. i have v 1.5 and my licence and all as i had it installed before i reinstalled windows xp. i just need a copy of it so i can install it again. any help apreciated. cheers
Drop me an email with you registration details & I'll sort you out.
