Hi
I am trying to convert an xvid + mp3 video source to xvid + ac3. So i used ffmpeggui(to extract an ac3 file from the source video) because i read some good reviews about it on this site. Worked ok so far in that i now have an ac3 file. Wondering what app i can use to join this ac3 file to the original video stream ??
Usually i use virtualdub for all my video editing needs but this is one situation it doesn't seem to be able to handle...
thanks
virtualdubmod, www.videohelp.com/faq#multiplex
but why??? when you reconvert the mp3 to ac3 it will make it worse. -
hmm, i didnt know it would make it worse..
The reason is that i am creating a dvd with dvd santa from the avi file. When i use santa with avi files that have pcm audio they never play back properly on my pc. When the source avi has an ac3 track there is no problem.
Although both types are fine on my standalone i thought i would improve the general compatability of my dvds but i didnt realise the sound quality would be effected..
How to stretch longer audio stream to a shorter video stream ?
By ralf07 in forum AudioReplies: 9Last Post: 31st Aug 2011, 22:42 -
ac3 audio and xvid video in avi out of sync
By socrates in forum Video ConversionReplies: 10Last Post: 15th Jul 2011, 21:58 -
join H.264 mp4 with a AC3/DTS/LPCM audio stream
By xrlem01 in forum Newbie / General discussionsReplies: 3Last Post: 29th Apr 2009, 08:09 -
How do you separate an AVI file into a video stream and an audio stream?
By VidHunter in forum MacReplies: 2Last Post: 1st May 2008, 03:27 -
LOAD CLICK AND LOW SOUND at join of 2 avi xvid ac3 using vitualdub
By hawklight in forum EditingReplies: 0Last Post: 15th Jul 2007, 08:44
