i have some .dat file and i want to burn it into dvd..
i have 3 choice..
1. change the .dat extenstion to .mpeg
2. use vcdgear355 to change .dat to mpeg.
3. use tmpegenc to reconvert it again.. to mpeg.
Results 1 to 11 of 11
1. This does nothing. Its still the same file and file type, it just changes how programs access it.
2. This is the best way. That is what the program is for.
3. There is no reason to re-encode the file. A dat file just contains an additional file header which needs to be stripped. That is what vcdgear is for. -
So you just don't want to have to manually do this for each file? Doesn't VCDGear have a batch processing option? The release history mentions batch processing.
Like I said, renaming the filetype might not take long but it accomplishes nothing. You'd get the same result by just telling your program (whatever program you are trying to load these into) to show "all files" and then selecting your dat file.
You said you want to burn these to DVD right? Well if these dat files are coming off a VCD then they are not DVD compliant. You need to re-encode the audio to 48kHz. So there's really no reason to even use VCDGear. Load the dat files into a demultiplexor like TMPGenc and demux to video and audio streams. Re-encode the audio to dvd compliant settings, then multiplex them back again. Now you're ready to author to compliant DVD. -
I've tried the batch processing and it takes a little while to set up. I've ended up just loading each one one by one if I have multiple files to convert.Originally Posted by adam
No need really - I drop them into VCDGear, then drop the MPEG(s) into TDA and let it do it on the fly. I have found this to be much quicker.Originally Posted by adamIf in doubt, Google it. -
TDA converts the audio to 48kHz for you? If not then the DVD is not compliant.Originally Posted by jimmalenko
Apparently it does, here's a guide.Originally Posted by adam"Art is making something out of nothing and selling it." - Frank Zappa
VCD Karaoke (MPEG DAT file)- removing the vocals
By tsrusa2002 in forum Video ConversionReplies: 12Last Post: 22nd May 2011, 03:51 -
DAT to MPEG 1
By MI6 in forum Video ConversionReplies: 14Last Post: 8th Feb 2009, 16:01 -
convert VCD.DAT/MPEG to RMVb with dual channel audio
By newbievideohelp in forum Video ConversionReplies: 15Last Post: 7th Nov 2008, 00:42 -
How to corp a dat or mpeg file to mpeg
By onlyrasel in forum VCDEasy GeneralReplies: 1Last Post: 27th Sep 2008, 00:18 -
dat to mpeg - no sound
By goshz in forum Newbie / General discussionsReplies: 9Last Post: 22nd Jun 2007, 05:24
