  1. Member LisaB's Avatar
    Playing around with GoldWave and Audicity, I couldn't find a good solution.
    Although GoldWave has a nice Batch Process option, it only offers the ability to create one output file for each input file.
    Basically, I just want to take 16 sequentially numbered wav files (or mp3 files) and concatenate them.
    Sure, I could open them all in either Goldwave or Audacity and then cut and paste each one in turn into a single sound window...but there has to be a better way!
    Any ideas?
  2. Member housepig's Avatar
    Jan 2003
    the Plains of Leng
    do a Google search for a program called Addawav - will do exactly what you are looking for, very fast.
    edit - here's the link
    - housepig
    Housepig Records
    out now:
    Various Artists "Six Doors"
    Unicorn "Playing With Light"
  3. Member LisaB's Avatar
    Thanks for the tip...
    I also discovered, strangely enough, that the freeware RAD Video Tools will do this very easily...
    GoldWave is such a fancy audio editor, and yet it can't do this one simple thing!
