I hope this is the right forum. I have been capturing and editing video to convert to SVCD for some time now, no problems. This is usually TV shows and I edit out the commercials. I capture at 352x480. Now that I have a DVD burner, I have tried some DVD captures. But, if I capture at 720x480 to an AVI file, I have trouble playing back the file in Virtualdub. It will play for about one second and then it seems that the audio is interrupted every second or so. I need to play the file as I am taking out commercials and I want to make sure the audio and video are synched up properly. Could it be that I need a faster processor ? My full system specs are in my profile but here are the important ones:
Win ME
ASUS A7V333 Via KT333
1.4 Ghz AMD Athlon XP 1600+
256Mb DDR SDRAM PC2100
120 Gig WD 7200rpm ATA-100 + 160 Gig WD 7200rpm AT
ATI AIW 7500 Radeon
Any help or words of wisdom would be appreciated !!!
Thanks !!
Playing back in VirtualDub? I don't think there's a play option - are you sure you're using the right software?
Regards,
Rob -
Well I guess I mean using Virtualdub's frameserver to send the file to Tmpgenc. There is a play option that you click on and the file plays. I check to make sure that I did get the commercials out and also to see if the audio is synched correctly. Sometimes in my catures the audio gets out-of-synch with the video and I don't know how to check it except to play the file in Virtualdub before I frameserve it to Tmpgenc.
I'd check the original avi file first - out of sync can easily happen with dropped frames during capture. There should be a box to tick when setting up capture to allow for dropped frames.
If the avi is fine then I'd cut each segment of the avi into a separate file and let TMPGEnc encode them separately.Regards,
Rob -
I agree that it is probably a high datarate issue. That happens to me when I capture uncompressed but NOT when I capture Huffy
This same thing happens to me when I edit with virtualdub after capping via my ADVC-100 into DV. Luckily the ADVC-100 has the audio synch lock feature. I just edit out the commercials by sight and it hasn't affected the sync on any of my caps though.
If in doubt, Google it. -
Thank you Nelson37, NickSaunders, and jimmalenko, I feel better now. I suspected that it was the high datarate. Nelson37 I will try WinDVD. I actually thought about changing my screen resolution but I don't think that will have any effect. I might try to upgrade the processor, I have been thinking about doing that for awhile.
Thanks again !!
New to editing with VirtualDub
By xNesX in forum EditingReplies: 2Last Post: 18th May 2011, 23:56 -
Editing FLV in VirtualDub
By CursedLemon in forum EditingReplies: 12Last Post: 29th Jul 2010, 23:02 -
Capturing DV - Editing with Virtualdub
By LSchafroth in forum Capturing and VCRReplies: 5Last Post: 27th Nov 2009, 20:19 -
Virtualdub, editing out faces?
By capman21 in forum Newbie / General discussionsReplies: 4Last Post: 2nd Mar 2009, 21:12 -
mp3 editing with VirtualDub
By tomchook in forum AudioReplies: 2Last Post: 2nd Jul 2008, 11:48
