Recently j had some trouble converting my DVDs. I must say that i have ripped lots without problems previous. Problems appeared first with "Tom Clancy's Netforce", then with "Vertical Limit" and so on. The problem is that when i try to burn with Nero 5541 it says that my stream is not compliant with vcd standards. If I continue it burns the cd but the audio is bronken and it seems to "break" the video too.
Any idea? I use Smartripper, Flask Mpeg and Nero.
Thehacker79
Well what were your settings? Did they comply with the vcd standards?
Are you using a different brand of media for this vcd? If so it may just be that your player can't read the disk properly. Try playing it on your computer and see if the problems are still there.
MKV conversion troubles
By Alexstarfire in forum Video ConversionReplies: 3Last Post: 7th Mar 2010, 14:10 -
.ts video conversion Troubles....
By camlachie in forum Video ConversionReplies: 17Last Post: 12th Apr 2009, 09:28 -
FLV Conversion troubles
By ruderenoxiii in forum Video ConversionReplies: 3Last Post: 6th Dec 2007, 14:04 -
ipod troubles...again!
By SE14man in forum Newbie / General discussionsReplies: 11Last Post: 12th Nov 2007, 20:52 -
TV Out Troubles.
By SE14man in forum Newbie / General discussionsReplies: 54Last Post: 11th Oct 2007, 16:55
