how do u do more then 2 passes with a divx or xvid codec? i need help please!
Hello,
Here's how with divx:
Hello!
First determine your encoding bitrate that is purely based on the length of the original video & the destination file size. Use Ecuadors Bitrate Calcuator for this - it is very accurate!
Then load original into VirtualDub...
1) Using VirtualDub: Do a multipass - 1st pass encode, encode performance: standard. Under Audio: choose NO Audio
Also choose a suitable log file name / folder
2) Using VirtualDub: Do a multipass - nth pass, encode performance: standard. Under Audio: choose NO Audio
Ensure update log file is selected
3) Using VirtualDub: Do a multipass - nth pass again, encode performance: SLOW. Under Audio: either recompress or direct stream copy.
You can choose to repeat step 2) as many times as you want but a total of 3 passes as above should be adequate.
The above steps shoud result in the fastest encode time without going overboard on the quality.
The first step will result in an uplayable AVI - don't worry the hard work has gone into the log file!
For steps 2) & 3) the resulting AVI video file for each pass will be overwritten by the next stage.
The resulting AVI quality should be 97-98% of original.
AndyWork you bloody thing.... -
damn man. thanks. do u know any other programs that can do 3 or more passes? and how to do them?
Gordian Knot (the full-blown one) can do up to seven passes, and allows you the finest of controls over every aspect of the compression and filtration.
http://www.divx-digest.com/articles/dvd2divx_gordianknot.html
That guide will see you through.
Cobra
In plasma TV "Number of pixels" and "Number of dots" it's not a same term?
By flash_os in forum Newbie / General discussionsReplies: 2Last Post: 23rd Aug 2011, 12:27 -
ffmpeg Number of stream maps must match number of output streams
By tmiller_15 in forum Blu-ray RippingReplies: 1Last Post: 13th Nov 2010, 06:20 -
More than 2 passes
By marioval in forum Authoring (DVD)Replies: 6Last Post: 15th Mar 2010, 05:59 -
ConvertXtoDVD encoding passes
By leghorn in forum Authoring (DVD)Replies: 5Last Post: 6th Aug 2009, 07:42 -
CCE SP2 number of VBR passes
By DRP in forum Video ConversionReplies: 1Last Post: 25th Oct 2008, 02:53
