You cannot do anything with the contents in a virtual disc mounted on Daemon. You can add or delete files in an ISO if you use WinISO. Then save.
Results 31 to 36 of 36
pjcwu256. No one said anything about altering the files within the iso image. You could save them out to a new folder and then access them, but you'd just have to save the files out to your hard disk again when you stripped the angles. This takes twice as much disk space and takes twice as long.
only_emo_kid. You need to at least try it once before asking all these questions. If you have DaemonTools installed then I don't see how you can possibly be lost as to how to mount the image. Its self explanatory...if you don't think so just read the instructions or follow one of the guides.
Once the image is mounted you use IFOEdit to strip the unwanted angles. Here is a guide. Its only 2 buttons to hit so there's not much to tell.
http://www.doom9.org/mpg/ifoedit-multiangle.htm#anglestrip
If you are unsure which IFO to load then open DVD Decryptor and hit mode->IFO. The IFO it selects is the one you want. This is what you will open if IFOEdit. -
only_emo_kidGuest
n/m.. I think I got it.. Before, I done this with each IFO file and the remove angles was greyed out on all of them? or maybe i'm just stupid
only_emo_kidGuest
OKAY!! I got it.. just the movie tho, can you point me in the right direction how to add the menu's and all back? Thx
Using DVD Decrypter should I use .ISO or .IFO file !
By augustya in forum DVD RippingReplies: 21Last Post: 29th Mar 2012, 12:44 -
DVD Decrypter to ISO file - missing
By mkr10001 in forum DVD RippingReplies: 4Last Post: 5th Jan 2011, 18:55 -
DVDFab HD Decrypter: no ISO created!
By taboo in forum DVD RippingReplies: 8Last Post: 5th Apr 2009, 23:25 -
Problems Creating ISO with DVD Fab Decrypter
By ViRaL1 in forum DVD RippingReplies: 1Last Post: 25th Jan 2009, 13:30 -
DVDFab HD Decrypter and BD iso
By rhegedus in forum DVD RippingReplies: 5Last Post: 13th Oct 2007, 06:13
