Alright, as topic says. I made an ISO of Mall Rats with DVD Decrypter and then loaded the ISO into dvd shrink, and then went to backup.. I was watching the video preview as it encoded... and I saw like a box come in front of the video as it played like the director commentary and then goes away, u know how they have the commentarys? well, I do'nt want that infront of my movie... so wtf? Thx
Results 1 to 30 of 36
only_emo_kidGuest
Uncheck the directors commentary audio before you backup with shrink
only_emo_kidGuest
.... I made the first ISO with DVD Decrypter and its not audio, its a video box in front of the movie..... **EDIT** Only sometimes it comes up, and only for about 15 seconds..
only_emo_kidGuest
I also haven't burned the dvd yet to a dvd-r and checked it out, so it might work right then, but i'm not quite so sure it will.. =\
You can also disable subtitles and substreams of insignificant sizes.
I added something to the statement.
You can disable video substrems of insignificant sizes. -
only_emo_kidGuestOriginally Posted by bazooka
only_emo_kidGuest
Okay, wasn't sure... It something I need to check on DVD Shrink correct? Because I don't have any dvd-rw or anything to test this one with...
only_emo_kidGuest
..I cancelled the encoding, and looked... I never encountered a dvd with the subpicture thing before, so thats new thing
Thanks!!
No problem and yes, you need to check the box that states disable audio and video substreams.
only_emo_kidGuest
.... I just done that, and watched the encoding again.. and damnit it's still there?!
There is another option to disable all subpictures except menu and forced streams.
You could try that. -
All I can tell you now is to explore the settings in decrypter.
It may be a prohibited Use Object.
You may need to delete the iso and disable the puo's in decrypter then rip and create a new iso. -
Originally Posted by only_emo_kid
only_emo_kidGuest
whut makes me wonder, that there is an untouched video file there is its a 7.7 GB ISO File
You could run the iso back through decrypter and possibly remove it that way.
Just switch decrypter to iso-read. -
only_emo_kidGuest
...Can I get rid of the unwated angle if I already have the .iso but don't have the dvd with me right now? Thx
You can just mount the image with Daemon Tools and it will be just like as if the DVD was in your dvd-rom. From there you can do whatever you want, including stripping the unwanted angles.
Yes but unless you strip out then angle then its still there. If you use DVD Shrink in reauthor mode you can just select the angle you want. But if you want a full backup then you've got to strip that angle out before hand, as far as I know.
You mount the image with Daemon Tools. This lets you access the image as if it were a DVD in your dvd-rom. There are many guides on this site which explain how to do this.
From there you have to strip the angles in something like IFOEdit. Again, there are guides on this site which explain how to do this.
Using DVD Decrypter should I use .ISO or .IFO file !
By augustya in forum DVD RippingReplies: 21Last Post: 29th Mar 2012, 11:44 -
DVD Decrypter to ISO file - missing
By mkr10001 in forum DVD RippingReplies: 4Last Post: 5th Jan 2011, 17:55 -
DVDFab HD Decrypter: no ISO created!
By taboo in forum DVD RippingReplies: 8Last Post: 5th Apr 2009, 22:25 -
Problems Creating ISO with DVD Fab Decrypter
By ViRaL1 in forum DVD RippingReplies: 1Last Post: 25th Jan 2009, 12:30 -
DVDFab HD Decrypter and BD iso
By rhegedus in forum DVD RippingReplies: 5Last Post: 13th Oct 2007, 05:13
