I've downloaded recently a video file from morpheus encoded in divx 4.02 but when I played it there was no sound. I opened up virtual dub & check the file info the audio compression unknown(tag 0161)but there is an audio embed on it. how do I re-encode the video to get the audio working? please advise. thanks!
This means you don't have the correct audio codec installed on your system. A divx video file can contain audio in severeal formats like MPEG4, MP3, PCM, uncompressed and so on.
For you to encode it to a format your system have support for, you first need to find out what audio has been used, and then install the correct codec so you can decode it. But then you would be able to play the sound so there will be no need to re-encode it!
Suggest you install the "Kristal Studio Pack" found under the tools section here on http://www.vcdhelp.com
Best regards Zulu Trax.
divx 2pass encode error
By ledishis in forum Video ConversionReplies: 3Last Post: 4th Apr 2012, 15:47 -
Is it worth to encode from DivX and/or XviD to BluRay?
By rocky12 in forum Newbie / General discussionsReplies: 4Last Post: 23rd Nov 2008, 11:53 -
How to encode DVd to DIVX with gui4ffmpeg
By gui4ffmpeg in forum User guidesReplies: 32Last Post: 21st Nov 2008, 05:02 -
Strange Error Message when trying to encode to DIVX
By Meiso in forum ffmpegX general discussionReplies: 1Last Post: 1st May 2008, 10:20 -
Trying to encode DVD to DIVX/AVI or h264
By cassavetes in forum ffmpegX general discussionReplies: 11Last Post: 25th Jun 2007, 11:46
