  1. I have just got a DVD writer. Previously I have been writing SVCD's onto CD using to play on my DVD Player. Now I would like to get the files from the CD's, join them & convert them so I can make a DVD. I tried to use TMPENC DVD author to convert the filesto DVD but it said that the 480x480 format was not compatable & also the audio which was 44k should have been 48k. What software should I use to convert the files
  2. https://www.videohelp.com/author#3;29
    Found in the Guides section under Author. Pick one that suits you best. SVCDs do not fit the requirements for DVDs, so a few small adjustments are necessary.
    Good luck,
    Cobra
  3. looks to be just what I want, thanks very much John
  4. If you have any specific troubles when following a guide, just post back up!
    Cobra
