Hi. I was using the latest version of ffdshow version 2004 October 12. It's the only codec I use and it plays everything.But, I just downloaded a trial version of InterVideo WinDVD 6 because I was following this audio encoding guide and it needs to use InterVideo's filters in Graphedit in order to work. When I try to open up an XviD in VdubMOD, an error pops up saying that it needs VFW. I do have VFW enabled for XviD. I restarted the computer and it still says that. In GSpot, I noticed that the video codec it's using is the InterVideo MPEG4 Video Decoder. Is there any way to switch back to FFDSHOW for all videos? I checked in WinDVD's preferences and I did not see any option to do that.
If I uninstall WinDVD, its filters will also be deleted and I need the filters in order to do the audio encoding.
I did set it. I went into ffdshow settings and enabled XviD. It didn't work. I went into the VFW Config and enabled XviD. It didn't work. The videos are playable in the players, but it won't open like they're supposed to in VdubMOD. That's the problem. If you must know, here's my settings:
FFDSHOW Configuration:
XviD - libavcodec
DivX 3 - libavcodec
DivX 4 - libavcodec
DivX 5 - libavcodec
FVFW,FFDS - disabled
VFW Configuration:
Encoder: MPEG 4
FOURCC: XVID
Decoder:
XviD - libavcodec
FVFW,FFDS - libavcodec
And here is the error message I got when opening these XviD files in VdubMOD:
Couldn't locate decompressor for format 'XVID' (unknown). VirtualDub requires a Video for Windows (VFW) compatible codec to decompress video. DirectShow codecs, such as those used by Windows Media Player, are not suitable. Only 'Direct stream copy' is available for this video.
BD-RE and ffdshow
By ttheb1 in forum Blu-ray RippingReplies: 12Last Post: 29th Jan 2011, 23:10 -
What is FFDshow?
By terrypin in forum DVD RippingReplies: 11Last Post: 7th Apr 2010, 17:26 -
Feedback: vbulletin, moticons interfering with web links
By vhelp in forum FeedbackReplies: 5Last Post: 31st Jan 2010, 16:52 -
using ffdshow with??
By uglijimus in forum Video ConversionReplies: 7Last Post: 18th Aug 2009, 23:55 -
AP reports Comcast Interfering with P2P File Sharing
By thecoalman in forum ComputerReplies: 6Last Post: 21st Oct 2007, 00:04
