I don't know much about DVD formats so excuse me for a silly question.
I would like to buy a Region 2 DVD with a movie, in PAL format. The question is: will it work on a laptop (which of course has a DVD drive)?
Thank you.
Hi mq,
It's your first post - welcome to the site and the forums.
Yes, you'll need the following if you haven't got them already:
1. One of the many DVD playing software. See "Video Players" in the "Tools" section (the link is on the left side of this page). PowerDVD and WinDVD are commonly praised.
2. An MPEG2 codec - it usually comes with the player. But I mention it in case it doesn't and you run into trouble.
3. Drives and or software are sometimes (usually?) restricted to the number of times you can change regions. Somewhere around 5 times.
So, if your laptop is set to region 2, you can play as many region 2 DVDs as you like. If you want to play a region 1 DVD, you'll have to change the region - that counts as 1 change. Changing back to region 2 is 1 more change.
However, there's software called DVD Region Free - that bypasses the "problem" / "issue" of number 3. There are other tools - just search for "region" in the "Tools" section.
Hope that helps some...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
EDIT:
Daamon beat me to it
DVD Drives for computers, by default, allow you to set one region for DVD playback, and then change this up to 4 times after that. Obviously you would be wise to leave this set on the region that the majority of your DVDs are from if you wish to use the DVD Drive for playback for any reasonable amount of time. Without knowing your location, I can't tell you what your "local" region is.
However, most DVD drives can be modded so that they'll play any region discs. Try http://forum.rpc1.org/dl_all.php and look for the DVD drive that is in your laptop. Alternatively, there is software (DVDGenie etc) that can handle this for you for a price.If in doubt, Google it. -
Ah, but you provided better links...Originally Posted by jimmalenko
Carpe diem.
Why is it an issue? You live in a region 2 country already. Any laptop you bought there should be already have the DVD-ROM set up for region 2.Originally Posted by mq
By the way, if you go into "profile" and put your country there it'll make it easier for members here to help you with questions like this one
And ....welcome to Videohelp, mq
Thank you for the welcome note.
I do live in a region 2 country, that much I knew already.
However, that does not imply that the dvd players on all laptops bought here are set for region 2. It depends on how they are imported: most are bought as they are from other countries, without any configuration for use in this area.
I would have mentioned my location if it could help, so that you wouldn't have to go through the trouble of traceing to my IP.
Laptop unable to play DVD-9
By LadyMiir in forum Software PlayingReplies: 8Last Post: 6th Jun 2011, 07:52 -
Recorded DVD won't play in my laptop
By vpanganiban in forum Software PlayingReplies: 7Last Post: 12th Dec 2008, 03:53 -
DVD-9 disc won't play on my laptop
By Yep in forum Software PlayingReplies: 6Last Post: 13th Nov 2007, 06:51 -
Will I be able to play DVD on laptop, edit it, etc.
By Roche in forum DVD & Blu-ray RecordersReplies: 3Last Post: 7th Nov 2007, 01:25 -
DVD Recorded discs won't play on Laptop!! ):
By SteveMKIIDub in forum Software PlayingReplies: 11Last Post: 21st May 2007, 18:24
