  1. Bought a brand new dvd today and when I went to copy it with dvd shrink the program just shut down, so I tried using dvd dcrypter to rip the files onto my computer then copy them like that, but instead of just shutting down dvd shrink says it encounters and error, it does not say what error though. Any ideas, could the disc have some kind of feature that prevents it from being copied ?
  2. Banned
    Sep 2004
    Inner Circle of Thought
    What versions are you using?
    You may need to upgrade.
    More info is needed.
  3. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Try with DVD Decrypter again, but this time take a screen dump of the error and post it here.
    If in doubt, Google it.
  4. Originally Posted by jimmalenko
    Why, dvd decrypter worked fine.
    The error message just says dvd shrink encounterd an error and now must shut down, it happens like 5 seconds in to the encoding phase.
  5. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    sorry, I meant DVDShrink
  6. Oh ok, thats cool but the message is dvd shrink encounted and error and it must reset, I am using dvd shrink 3.2
  7. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    try using a older version of DVD SHRINK.
    http://www.mrbass.org/dvdshrink/dvdshrinkold/
    like version 3.05 beta but it doesn't have the built in NERO BURN feature.
