    Anyone else experience sound problems in DVD Shrink 3.2? Sometimes the sync of voices is off or the sounds is really low. It could be my media but just wanted to see if anyone had these problems or know of other causes. Thx
  2. Hi Lethalwordz.
    Does this happen when playing the "shrunk" files from your hard-drive, or only when playing the disc?
    ddlooping
    For DVD Shrink guides & goodies: DVDShrink.info
    My "other" site: Teaching-Tools
    Playing it off the disc.
  4. Can I then assume it plays normally from your hard-drive?
    If yes, it would point towards a burning problem of some sort.
    What burning software do you use?
    What media are you burning to?
    What speed are you burning at?
    ddlooping
    I dunno if it plays on hard drive, its just a .iso file. didnt use isobuster or anything. The burning program is nero, at 4x. The media is kinda cheap...legacy. I noticed on my TDK disc the lip sync was off and was a bit low of volume (maybe cuz its ac3?).
  6. Well, it would help if you could play the ISO from the h-d, just to make sure the problem is not already there.
    Using "Daemon Tools" you could "mount" the image, and then play it just as if it was a DVD.
    ddlooping
