I am using After Effects to make a title I can use at the beginning of my personal DVDs (Like MGM, 20th Century Fox, etc) that runs about 15 seconds. I want to tack it at the beginning of my DVDs. I've had no problem with After Effects, but I need to convert it to mpeg or .vob to use it. I am creating the AVI (no mpeg in AE) in 720x480 format. When I convert it to NTSC DVD compliant mpeg in Vegas, the aspect ratio is always off. The composition has a large circle in the middle that always looks like an elipse when rendered.
I know it probably has something to do with pixels (square or not) or aspect ratio settings. I know enough not to use 4:3 (vertical elipse) or 16:9 (horizontal elipse). I've tried every option given in Vegas and the circles either come out as horizontal or verticle elipses. Any advice?
If it works, don't fix it.
Multiple Aspect Ratios on One Disc
By gorcq in forum Authoring (DVD)Replies: 7Last Post: 20th Dec 2011, 22:35 -
MPEG-1 on DVD with different aspect ratios
By DRP in forum Authoring (DVD)Replies: 8Last Post: 15th Aug 2010, 03:16 -
iMovie and aspect ratios
By sphinx99 in forum MacReplies: 3Last Post: 11th Mar 2010, 00:18 -
multiple aspect ratios on one DVD?
By towtruck in forum Authoring (DVD)Replies: 11Last Post: 7th Jul 2008, 03:58 -
Aspect Ratios
By gayclarke in forum Authoring (DVD)Replies: 3Last Post: 15th Sep 2007, 16:13
