  1. Member garman's Avatar
    Sep 2001
    Guantanamo Bay, Cuba
    What is a good peer to peer program for a macintosh.
    OS 9 would be good if not OSX will do. Thanks garman
  2. Banned
    Sep 2004
    Inner Circle of Thought
    Check out www.zeropaid.com
  3. Member Faustus's Avatar
    Apr 2002
    Dallas, TX
    P2p on mac? I'm gonna be honest and say welcome to a waste land. Check out Bit Torrent or something.
  4. Banned
    Sep 2004
    There are programs out there.
    Like I said, try www.zeropaid.com
  5. Member garman's Avatar
    Sep 2001
    I'll give it a go!
    thanks
  6. Banned
    Sep 2004
    No problem.
    xFactor
    Program Directory > File Sharing Applications > Multi-Network Support 9 Works on Mac
    2 Poisoned
    Program Directory > File Sharing Applications > Multi-Network Support 14 Works on Mac
    3 Phex
    Program Directory > File Sharing Applications > Gnutella Network > Gnutella Open Source Projects 34 Works on WindowsWorks on MacWorks on Linux
    4 Overnet
    Program Directory > File Sharing Applications > Other Networks 60 Works on WindowsWorks on MacWorks on Linux
    5 Mute
    Program Directory > File Sharing Applications > Other Networks 5 Works on WindowsWorks on MacWorks on Linux
    6 MLDonkey
    Program Directory > File Sharing Applications > Multi-Network Support 11 Works on WindowsWorks on MacWorks on Linux
    7 MacFreenet
    Program Directory > File Sharing Applications > Freenet Network 4 Works on WindowsWorks on MacWorks on Linux
    8 LimeWire
    Program Directory > File Sharing Applications > Gnutella Network 162 Works on WindowsWorks on MacWorks on Linux
    9 iTunes
    Program Directory > File Sharing Applications > Paid Service 3 Works on WindowsWorks on MacWorks on Linux
    10 Carracho
    Program Directory > File Sharing Applications > Other Networks 35 Works on WindowsWorks on MacWorks on Linux
    11 BitTorrent
    Program Directory > File Sharing Applications > Web Based Services 77 Works on WindowsWorks on MacWorks on Linux
    12 Acquisition
  7. Member garman's Avatar
    Sep 2001
    Do any of those apps work behind a firewall!
    -garman
  8. Member Faustus's Avatar
    Apr 2002
    Dallas, TX
    Unless you control the firewall... doubtful. Thats why its called a firewall.
