How much mpeg 2 can you get on a 4.7 dvd with TMPENG 1.6 ? If I try to burn a dvd over 90 -93 minutes of material it goes into overload and will not burn the DVD. I am using a Plextor 708 and using Sony Dvd disks.
Is there something I'm missing ? Is mpeg 1 a costlier [ video quality ]
way of doing things.... 104 minutes on 2 DVD's seems a little silly ..Thankx a lot .....Any help is appreciated.
Yes - Don't think in terms of time, think in terms of filesizes.Originally Posted by bkoyx
Obviously, a DVD5 (single layer DVD) has a finite amount of storage space - about 4.35Gb available for all your video, audio, menu, subs etc. The rest is used by what's called "disc overheads".
When an MPEG2 file is created, it's filesize is dictated by the bitrate during encoding and the length of the footage in terms of time.
So, a 1 hour movie encoded @ 4,000kbps will be the same filesize as a 30 min movie @ 8,000kbps etc.
Use the VideoHelp Bitrate Calculator to figure out what your bitrate should be for your encoding - don't forget to plug in the audio bitrate you're using.
Have a look at it in Advanced Mode - it'll give more of an insight into what's going on...
Hope that helps some...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
It's not the authoring program, it's the size of your mpegs that matters.
Burning to Full Capacity of a DVD
By Agent 5 in forum MediaReplies: 6Last Post: 16th Apr 2012, 10:49 -
Simple question on DVD+R DL discs/Capacity
By alegator in forum MediaReplies: 12Last Post: 19th May 2011, 05:52 -
Exact maximum capacity of DVD+R
By geohei in forum Authoring (DVD)Replies: 18Last Post: 21st Mar 2009, 10:23 -
Tmpeg DVD Author doesn't like low quality captures?
By the wordsmith in forum Video ConversionReplies: 9Last Post: 20th Mar 2008, 07:30 -
Low End Video Card w/ adapter vs. Low End DVD player
By enter8 in forum Media Center PC / MediaCentersReplies: 6Last Post: 20th Aug 2007, 16:45
