In adding movie into TMPGenc DVD author project, I was asked to select the audio input (my movie has 2). Does anyone succeed in keeping all the audio from the original movie, or I should try something else?
Thanks a lot for your opinion.
I'm pretty sure you can only have 1 audio stream. You could convert the two streams to mono and then joint them together or use another authoring tool. DVD Author is free and worth a look. https://www.videohelp.com/tools?tool=GUI_for_dvdauthor
Thank you Steve, I'll give GUI for DVDAuthor a try. Just wonder why a popular tool like TMPGenc DVD Author does not work as I expected!
Hey what's the difference between GUI for DVDAuthor and DVDAuthorGUI? I'm looking at crossing over to one of these too, for exactly the same reason (2nd audio commentary etc). Do they both do the same things?
u mean your movie have 2 audio? For instance english/spanish then you can use Bilingual in Tmpegenc DVD Authoring..
I think if you have two mono audio tracks on one stereo track then you can use it, but for seperate DTS, DD you can only have one. If i'm wrong i'd love to be corrected!
He's a liar and a murderer, and I say that with all due respect.
audio encoding: tmgenc dvd author 3 vs. tmpgenc plus
By cL0N31 in forum Newbie / General discussionsReplies: 0Last Post: 7th Jan 2009, 00:25 -
Normalize Audio with TMPGEnc DVD Author 3?
By jonas more in forum AudioReplies: 2Last Post: 16th Oct 2008, 22:10 -
TMPGEnc Author Version 2.0 - Unable to make a DVD with a motion Menu
By tug_hill2 in forum Authoring (DVD)Replies: 5Last Post: 28th Sep 2007, 01:37 -
How to Make Authored DVD INTO .ISO WITH TMPGENC DVD AUTHOR
By Chupes in forum User guidesReplies: 4Last Post: 19th Aug 2007, 18:38 -
Background audio with still image on TMPGEnc DVD Author?
By tikigod19 in forum Authoring (DVD)Replies: 7Last Post: 7th Aug 2007, 14:44
