does Philips 642 play OGM?? will does it??
OGM isn't listed anywhere, so I doubt it. Might have to convert to MP3.
no it doesn't
Personally, I don't think it's a big as it is pretty easy to convert ogm to avi, problem is that the file will probably be larger than 700 b if the ogm file was originally 700mb.
It sure is better than having to re-encode the video of a file that uses Qpel or GMC -
i tried to play some ogm video files.. they didn't work. i tried to rename them as avi's to trick the player.. but it couldn't really handle them.. it kept skipping.. it couldn't keep up with the audio (or knew how to do it).
worked fine on my xbox though
Philips DVP-642 16:9 Display
By wulf109 in forum DVD & Blu-ray WritersReplies: 4Last Post: 27th Jan 2010, 12:39 -
Philips dvp 642 help?
By imemine in forum DVD & Blu-ray PlayersReplies: 7Last Post: 3rd Feb 2009, 02:22 -
Philips DVD 642/37 Mostly a Blue Picture
By Shieh in forum Newbie / General discussionsReplies: 3Last Post: 3rd Feb 2008, 11:32 -
Philips DVP 642 (37A) dvd player -does it play PAL
By Katiemay in forum DVD & Blu-ray PlayersReplies: 8Last Post: 11th Jun 2007, 23:16 -
Philips DVP-642 and x.264 HD encoding
By dfishman923 in forum Newbie / General discussionsReplies: 2Last Post: 13th May 2007, 14:36
