  1. Hi,
    I have been converting avis to skvcd with diko.
    Diko produces bin/cue files to burn the movie to cd with.
    I was just wondering if it makes a difference which program you use for the burning. Are there any quality variables or is it just a question of if it works, it works.
    At the moment i'm using a freeware program called burnatonce to burn these bin/cues
    if the resultant ksvcds are working should i not be worried?
    Many thanks to anyone who can help me.
    Kian
  2. Hi!
    It doesn't matter what kind of burning program you're using to burn the bin-files. If it works with the program you're using, then there's no reason to change that.
    // Znooky
  3. thank you very much znooky
