Im trying to reinstall win98 on a system (i created a boot disk and burned cab files onto a cd-r)
Ive ran autoexec.bat and mscdex.exe, and ran setup.exe, but then it says my drive doesn't have a valid fat 32 system on it. Ive tried running every option possible in fdisk and nothing works to create or delete partitions.
Ive also tried formatting C: but it says format isnt supported on drive c:
Results 1 to 9 of 9
I think you will have to boot from a floppy disk to use fdisk in that way. A CD boot may work, but a floppy is a lot easier, at least for partitioning and formating.
Have you set your BIOS to boot from a floppy? Then fdisk should work just fine. The W98 system files can be added after the repartition and reformat. -
The boot sequence is A, CDROM, C
Im thinkin also the HD may be corrupted, because when i tried a disk copy with drive image it said "error bad pointer" -
Get vendor of HD and see if on the Mfg web site they offer 1) diags and 2) low-level format utility.
HTH -
You could also try to use the DOS bootdisk and delete the active partition.
Create a new partition and format it.
Then you start trying to install again. -
Which method worked.Originally Posted by spider12
I am glad whatever you did worked. -
dlded a low level format software from the fujitsu site, putit on a floppy then ran it through dos.
Yea, i tried to delete any partition from fdisk but it wouldnt let me.You could also try to use the DOS bootdisk and delete the active partition.
Win95, Win98 and WinXP
By Jomapil in forum ComputerReplies: 9Last Post: 4th May 2009, 13:41 -
Win98 Generic drivers?
By bevills1 in forum ComputerReplies: 4Last Post: 30th May 2008, 14:44 -
Ipod and Win98?
By capman21 in forum ComputerReplies: 2Last Post: 27th Sep 2007, 12:04 -
I have to ask again, trying to installing Win98.
By capman21 in forum ComputerReplies: 45Last Post: 23rd Jun 2007, 12:38 -
Win98 update problem
By bevills1 in forum ComputerReplies: 22Last Post: 7th Jun 2007, 14:36
