have had over a year with no problems. have not changed system BUT drawer will not open and light continually flashes but is not spinning. have disk inside but says insert disk. any suggestions![]()
Results 1 to 10 of 10
Remember to break long term aims into short term projects
Is taking it back an option for you?Originally Posted by m.tweedyOriginally Posted by lordsmurf
Just a suggestion, but have you tried restarting the computer?
Originally Posted by lordsmurf -
Have you tried putting a pin in that hole in front to push the disk out? Thats what its there for.
Say, after that, see if it works. -
this has happened to me also, it happened about a month ago. i emailed sony and all they had to tell me was send it in for repair(which i havent done). and to get the disc out you have to take the face plate off and wind the cogs manually. im now saving for a newer dual layered drive, i see no point in having it repaired.
Heres to alcohol, the cause of, and solution to all of lifes problems. -
this is common with the dru510a, search this site or google for other peoples experiences
it happened to mine and i sent it back and got a replacement
use a paperclip to get the cd out, poke it in the little hole on the front of the face
bottom line is its cactus -
out of warranty and have restarted computer a number of times and have previously removed disk manually and re inserted it to see if it cured problem. no joy. seems totally cattle trucked.
Remember to break long term aims into short term projects -
I've been having problems with my Sony DRU510AK lately too. I thought it was SP2 so I formatted and went back to SP1 (XP Pro) but I still can't play DVDs. Thinking this drive might be dodgy. It still writes and read pretty much any disc except for DVDs, but that's not too useful.
sony now in bin. new pioneer dvi108 dual layer dual format working. the dogs b***. and only £65. thanks for all responses. the sony is dead long live the pioneer..
Smart render in Sony Vegas 11 for Sony Bloggie MHS-FS3 mp4 files
By ekendahl in forum EditingReplies: 8Last Post: 27th Aug 2011, 18:41 -
Importing avi (divx) Files in Sony DVD Architect/Sony Vegas
By mltwitz in forum Video ConversionReplies: 12Last Post: 6th Jan 2011, 06:56 -
Wedding Videography Sony HDC 900 or Sony PMW EX3 ? Tapes?
By mek in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 26th Oct 2010, 13:35 -
Sony TVR-460 with FireWire cable 4pin undetected by Sony Vaio Laptop
By vatsyk in forum Capturing and VCRReplies: 4Last Post: 11th Dec 2009, 17:45 -
Importing from SONY HDR-SR1 to SONY VEGAS 8 MPEG Video resolution
By UltimateEnd in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 19th Oct 2009, 11:00
