Ok I am converting divx to vcd and was wondering what I should do in TMPGEnc 12a to get the absolute best quality. Can anyone tell me what to check and what to choose for all the options? Thanks.
First of all, ditch TMPGENc 12a and get 2.01, its much faster and has better quality. Goto Settings and select whatever bitrate you want (the higher, the better, but also has higher CD consumption). Now encode!
BTW Is your DivX good quality? Coz if it isn't you can't improve the quality of your VCD.
Garbage in-->Garbage out
I only dream in black & white...
MSN: paschendale@gmail.com -
On 2001-11-27 00:01:01, Dhruv wrote:
First of all, ditch TMPGENc 12a and get 2.01, its much faster and has better quality.</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
I got this one first but everytime I try to load the divx into it I get "... cannot be opened or is unsupported" where with 12a I can actually make VCDs. Why won't the new one work for me? -
Uninstalled Divx 4 codec and install Divx 3.11 codec and now TMPGEnc 2.01 opens up divx just fine. Weird.
Absolute newb confusion. Buy a digital camera.
By Early Grace in forum Newbie / General discussionsReplies: 6Last Post: 29th Sep 2010, 16:49 -
what's the absolute funniest movie you have ever seen?
By deadrats in forum Off topicReplies: 15Last Post: 7th Jun 2010, 21:13 -
The absolute best method to convert to AppleTV?
By DiGNAN17 in forum Video ConversionReplies: 10Last Post: 26th Aug 2009, 01:05 -
an ABSOLUTE, GUARANTEED 100% backup method using-it's NEVER failed for me!!
By fonzbear2000 in forum User guidesReplies: 25Last Post: 21st Oct 2007, 22:08 -
What is the ABSOLUTE BEST quality DVD ripper?
By Saif in forum DVD RippingReplies: 8Last Post: 17th Sep 2007, 20:31
