need help, trying to copy vcd, i have a copy of tombraider, the dics it came on didnt work on my dvd player so i want to burn it to a dics that does,
so far i have had no luck,
could it be because my pc's dvd player is a region 2?
can some one shed some light?
1.) Are you sure your DVD Plays VCD's?
2.) If it's a pressed (commercial) VCD it should work if yuor DVD player plays VCD's.
3.) If its not a commercial VCD there is not region coding that effects copying.
4.) What disc copy program are you using?
5.) You can extract the *.dat file from the VCD and generate a new mpeg with VCDgear. This newly generated mpeg you can authorize into the normal VCD specifics with Nero etc.
I don't want to make a judgment of you. If this is the movie release you are talking about then wouldn't it be less aggravating and time consuming if you wait for the home video release in November. Four months not too far away. Then you could have a better quality copy to rip from?
<font size=-1>[ This Message was edited by: moog on 2001-07-14 15:54:40 ]</font>
DVDFab Blu-ray Copy vs. DVD Copy
By coody in forum Blu-ray RippingReplies: 1Last Post: 11th Oct 2010, 12:33 -
How do i copy dvds onto hard drive and what is best software to copy sav
By bfishwick in forum Newbie / General discussionsReplies: 1Last Post: 13th Feb 2009, 17:29 -
Is copy Sony PSP game same as copy DVD disc?
By coody in forum ComputerReplies: 10Last Post: 15th Dec 2008, 07:26 -
How can I copy a copy-protected DVD and have only ONE VOB file
By Aafour in forum DVD RippingReplies: 3Last Post: 6th Oct 2008, 00:31 -
Unable to copy copy-protected data DVD
By J_Kirk in forum ComputerReplies: 9Last Post: 22nd Jan 2008, 11:23
