Greetings:
After taking a 2H video clip of a funeral on a Sony DI8. I use Media Studio pro 7 to capture & render to a 86 minute AVI file (18GB) without any special effects (just have an indroduction in text format) and compress it to mpeg2 (~1.5GB) file. Many time I want to burn either file to a DVD+R (either no brand or Sony 4X) using Nero Vision Express 2 (Nero ultra ed. 6), it failed at about 1h30mn remaining time. I receive this message "Unable to prepare data for encoding: Transcoding of videos failed: Transcoding of video failed. (internal error 2009231111)". Am I missing something? Any suggestion and help is greatly appreciated.
My rig:
- Abit IS-7 Mobo
- P4 2.8E GHz 800FSB
- 1X PMI3200 512MB Dual channel turbo PC 3200 DDR400
- 2X WD1200JBRTL 120GB 8MB buffer ATA 100 with multiple NTFS partition (4GB OS w/ 1.2GB free, 6.5GB program 1.32GB free, 1.2GB swap 480MB free, 28GB video1 20GB free , 28GB video2 15GB free, 110GB free videotmp partition).
- 16X Nec ND3500A Dual layer DVD-/+RW
- 128MB Nvidia Quadro 750XGL
- Antec 430W TruePower power supply
- XP Prof. sp1
- All video partition is defragmented.
you appear to be re-encoding your already encoded files - which is a big no no ..
see guides on how to encode for DVD and see guides for authroing your dvd - which you must do before burning ,..."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
yep, get a good authoring tool that doesn't reconvert like tmpgenc dvd author!
Nero Vision TSmuxergui converting MKV files
By vieya in forum Video ConversionReplies: 1Last Post: 30th Nov 2009, 12:47 -
HELP Burn using Nero Express doent work /but NERO VISION work fine
By STAR36 in forum Authoring (DVD)Replies: 4Last Post: 28th Apr 2008, 17:11 -
How do I burn MP4 files to a DVD video using NERO Express 3
By magikero01 in forum Newbie / General discussionsReplies: 5Last Post: 23rd Feb 2008, 09:26 -
Unable to burn with multiple DVD recorders with Nero 7.9.6.0
By Burner127 in forum Authoring (DVD)Replies: 1Last Post: 7th Jun 2007, 00:47 -
join and burn using winavi and nero vision express?
By leogeo in forum Authoring (DVD)Replies: 9Last Post: 11th May 2007, 07:56
