I have an mkv file, and when I open it using mkvtoolnix there seems to be a track with the tag VOBSUB. As far as I can tell (by playing the file) that seems to be an idx/sub file.
I wanna know if there is a way to extract this, and/or if I can put this format in my own DVD-Rips.
mkvextractgui and you can use latest gordian knot beta and make mkv.
Hi.
I have an mkv file too and I tried to convert it in avi format with mkvextractgui first like explain in this forum. The video and the sound were perfectly extracted, but the subtitles did not. I have the same problem as Monotone, mkvextractgui skips over the subtitle. It is said "warning: Unsupported CodecID 'S_VOBSUB'". I have also tried with VirtualDubMod but it failed to open the file : "Only handle [S_TEXT/] subs for the moment"!! So how can I extract this subtitle ?
Thanks for your help. -
Not sure that extracting VOBSubs is possible, from what I remember adding them is not a lossy process, unneeded data is stripped and the file is compressed with zlib or similar. Now uncompressing would not be an issue, however the stripped data I guess is.
Mkv + idx + sub
By dazler in forum SubtitleReplies: 6Last Post: 13th Feb 2012, 13:49 -
How to add idx/sub hard subtitles to mkv
By 2ndlife in forum SubtitleReplies: 5Last Post: 29th Dec 2011, 21:22 -
I want to know how to put IDX on MKV
By hotboy87 in forum SubtitleReplies: 5Last Post: 13th Mar 2010, 13:57 -
Can't display embedded Idx/Sub (softsubtitles) in mkv.
By dsteff in forum SubtitleReplies: 1Last Post: 23rd Nov 2009, 23:01 -
Help with converting DVB subtitles to idx/vob subtitles
By Talayero in forum SubtitleReplies: 8Last Post: 21st Feb 2009, 17:10
