Results 1 to 11 of 11
  1. Hi guys.
    I'm in the process of re-editing our wedding vid for final authoring to DVD. Only problem is the DVD that was done at the resort in Antigua is NTSC, even though I implicity told the guy I needed it to be in PAL format as I want to edit in some footage from my DV camcorder which is also PAL.
    Just wondering if anyone knows of a process to convert NTSC to PAL other than this one that I can't get to work
    I've searched the forum and was hopeful since this thread there was a solution.
    My DV cam is a Sony PC9E which has dv in/out so is it feasable to record directly into my cam from my Sony DAVS500 DVD player and if so how?
    I'm editing in Premiere Pro.
    Great forum btw, I see lot's of help for Premiere Pro which is going to be cool for me
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    just get canopus procoder express -- does a great job
  3. Wow that was quick!
    Thanks, I'll give it a go
  4. Well I gave the canopus procoder a go and didn't have much success with it. I tried converting the vob files from NTSC to PAL and kept getting "Procoder detected stalling in the conversion...." which stopped the process. So I tried converting them as mpeg, which worked but the play back in PAL was less than satisfactory, dropped frames, repeated frames and playback freezing... maybe my pc is just not powerful enough to use this tool
    Anyway I found another way. I grabbed the video using Uleads DVD MovieFactory, started an PAL project in Uleads Media Studio Pro 7 then used the "convert" feature.
    Works like a charm
    I've just tested the converted video with edited in video captured from my PAL DVcam in Premiere Pro, burnt a sample to DVD and everything looks sweet
    Just thought I'd let you all know in case anyone else wants to do the same
  5. Member rhegedus's Avatar
    on the jazz
    Or you could just do nothing - most PAL DVD players can play NTSC without a problem so mixing formats shouldn't be a problem either, just so long as they are separate VOBs.
    Regards,
    Rob
  6. Yeah but like I said in my initial post I wanted to edit in some video that is in PAL.
  7. Member rhegedus's Avatar
    on the jazz
    Right, so what's that to to with NTSC conversion?
    Regards,
    Rob
  8. Edit it in NTSC and author it. As rhegedus says, most UK players support NTSC just fine. On a PC, editing video will work regardless of the framerate.
    Cobra
  9. Member rhegedus's Avatar
    on the jazz
    Sorry, I just understood what you meant - you want to blend some NTSC and PAL clips together to make one clip, not just put separate clips together.
    Glad Ulead worked for you
    Regards,
    Rob
  10. Originally Posted by rhegedus
    Yeah me too
  11. Try DVDSanta. Very simple and worked good for me....Terence
