Have downloaded the xvid codec Divx pro 5.2.1 to enable TPMPGnc Plus to read xvid files which worked fine, but when playing the xvid file before encoding I cant get any sound, the picture is fine but no sound!!
Any help greatly appreciated
Results 1 to 9 of 9
use gspot to identify if you miss any audio codec like ac3
or
https://www.videohelp.com/forum/viewtopic.php?t=241895
https://www.videohelp.com/forum/viewtopic.php?t=241895 -
Im not playing them through TMPgEnc, Im playing them through windows media player to check they are ok before I go to encode them throgh TMPGEnc
Try playing it with VLC media player. If it plays OK with sound, then you probably do have a codec problem. BTW, what did Gspot say the audio format was?
That an AVI plays in Media Player tells you absolutely nothing about the integrity of the AVI.Im playing them through windows media player to check they are ok
/Mats -
TMPGEnc doesn't do AC3 audio, if that's what's in the AVI. (XviD is a video codec, and has nothing to do with audio related problems.)
/Mats -
The general procedure is to extract audio and decode to WAV before letting it on to TMPGEnc, but if it works, fine!
/Mats
Xvid AVI DVD Playback Audio Sync Problems
By lozza_c in forum Newbie / General discussionsReplies: 5Last Post: 8th Jun 2008, 08:38 -
Problems with Xvid audio stream
By mijman in forum Authoring (DVD)Replies: 3Last Post: 15th Apr 2008, 22:59 -
WMV Conversion to Xvid - Audio Synch Problems Again
By TonyRomo1227 in forum Video ConversionReplies: 10Last Post: 6th Aug 2007, 16:32 -
Audio Problems with divx,xvid etc on dvd player
By iain123 in forum AudioReplies: 6Last Post: 30th Jun 2007, 14:57 -
vob/ifo to xvid audio sync problems.
By spiked in forum Video ConversionReplies: 4Last Post: 21st Jun 2007, 17:19
