Results 1 to 28 of 28
    Dec 2003
    Norway
    I got a region2 dvd image on my computer, but I'd like to convert it to region1 before I burn it. is that possible?
  2. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    rip it with dvd shrink with no compression. it will then make the dvd region free then burn with your fav burning program.
  3. why whould you want to do that?
    why not make it region free?
    anyway, i think you can do both if you run it through DVD Shrink,
    you dont have to compress it if it fits on a dvdr.
    HELL AINT A BAD PLACE TO BE
  4. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Don't forget that some players will only play region-set discs (and not region-free discs) by default
    If in doubt, Google it.
  5. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Because some DVD players are region locked(especially older Sony models) and will ONLY play a DVD that has the correct region code.
    A friend of mine in America has such a Sony DVD Player. It spits out region free discs(ALL region free discs including factory pressed region free discs) but plays a DVDR set to Region 1 perfectly.
    Jim beat me to it....he types faster and more "to the point"..
  6. lets buy the guy a 30$ multizone dvd and send it to him,
    will save him a lot of hassle !
    :P
    Dec 2003
    Norway
    I can't rip it, I only have the image. will dvdshrink still work?
  8. Member rhegedus's Avatar
    on the jazz
    Mount the image on a virtual drive using Daemon tools and rip the virtual drive.
    Regards,
    Rob
  9. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Newer version do:
  10. Member waheed's Avatar
    Jul 2003
    Manchester, UK
    I dont see how that would be possible. What about playing home made movies, a wedding dvd, etc etc.. Those dvds are region free as they are home made, so you're saying some dvd players aren't capable of playing these discs.
  11. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Yes.
    Some (though mostly older model) DVD Players are region locked and will only play a region coded disc. My friend has one in America....an older Sony with no region free hack available.
  12. Member NamPla's Avatar
    Jun 2004
    Whoop Whoop
    WHAT? A DVD PLAYER WITH NO REGION-FREE HACK???
    Ha... DVD Decrypter or DVD Shrink should rip your movie into ANY region you want! No degradation of quality!!!
  13. Member rhegedus's Avatar
    on the jazz
    My JVC XVS300 has no region hack
    But then I've got another 2 DVD players to watch region 1 stuff on
    Regards,
    Rob
    Dec 2003
    Norway
    cool, I'll try it out...
    Dec 2003
    Norway
    ok, I don't see how I can make it into region1 or region-free. do I just the iso after opening it or what?
  16. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Yep. exactly. These players need region-encoded discs. If you put region-free DVDRs into them, they'll just look at you with a "NO_DISC" look on their faces.
    @Amaze:
    Start DVDShrink. Go to File > Open Disc Image, specify the ISO and let DVDShrink open it. Click the Backup! button, and one of the tabs will look like the following:
    If you can play region-free discs, leave region free ticked. If you can only play region 1 discs, you need to untick the region free box and tick the region 1 box. When you're happy with your settings on all of the tabs, click OK and DVDShrink will do its thing. I've got a funny feeling IFOEdit could change the region for you also, but AFAIK to do it is not real NOOB-friendly.
    Dec 2003
    Norway
    thanks, worked like a charm, it was fast too...
  18. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    no problemo
    Dec 2003
    Norway
    one issue had to come up though of course. see, the dvd is in pal, and doesn't like to play on ntsc-tv's. can I reencode it into ntsc?
  20. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    You could attempt a PAL-to-NTSC conversion - there's a few guides here, but If I were you I would just watch the DVD on your PC.
    Dec 2003
    Norway
    that seems to deal with ifo-files only?
  22. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    What does ?
  23. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    OK. So what ?
    The IFOs are what controls how the DVD will display, so follow the guide perhaps ?
  24. Member
    Dec 2003
    Norway
    I don't have any ifo-files, I have one iso.
  25. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    ... and inside that ISO are the IFO, BUP and VOB files. You need to either extract these files from the ISO using WinRAR or ISOBuster, or mount the ISO with Daemon tools.
  26. Member
    Dec 2003
    Norway
    I see, thank you for your patience...
  27. Member
    Dec 2003
    Norway
    sorry to bring this up again, but it didn't work too well. how do I go about this the hard way, as in encoding?
