Hi,
Which of this player is suitable for watching dvd's and occasionally mp3/cd. also i was checking it has only 2 options for audio settings -PCM,RAW...Which of this mode is ideal for dts,dolby setting so that receiver should decode proper signal
--rubs
I don't know about the Toshiba, but the Philips can do what you want. Set the audio to RAW if you want your receiver to decode it.
How do you set the audio to RAW on DVP-642. I couln't see any option to allow me that.
Remote for Philips DVP642
By Melina in forum DVD & Blu-ray PlayersReplies: 2Last Post: 10th Jun 2010, 22:54 -
Philips DVP642 finally died...
By Krispy Kritter in forum DVD & Blu-ray PlayersReplies: 0Last Post: 3rd Feb 2009, 14:06 -
Original part# remote control f/ toshiba Sd -3960
By thebirdf in forum Newbie / General discussionsReplies: 0Last Post: 20th Jun 2008, 16:17 -
Philips DVP 3960 -- upconvert component?
By kruuth in forum DVD & Blu-ray PlayersReplies: 1Last Post: 29th Jan 2008, 10:42 -
Output resolution for Philips DVP642
By cheerful in forum DVD & Blu-ray PlayersReplies: 1Last Post: 3rd Aug 2007, 00:41
