god damn... i been looking forever for someone to help me to resize my damn avi file so it wont overscan on my Philips DVP642. I want to know a easy wasy to resize the damn avi(add those black boarders) file with out loseing any quality. Im trying to put my anime avi files on a DVD+R to i can watch it on my DVD player.. so i dont want to convert it to a different format.... OK!!!!!![]()
HELP NEEDDED FAST!!!!!!!
Results 1 to 23 of 23
You cannot do it.
AVI is not DVD-Video format.
You need to re-encode, no way around it.Want my help? Ask here! (not via PM!)
You can have a look at the following link. I don't know if that will help you.
http://www.doom9.org/mpg/avistretching.htm -
Originally Posted by moneylee
You have a unit that doubles as a .... what.... DIVX player?
Not all "AVI" are the same kind of files.
I'm not out of date.Want my help? Ask here! (not via PM!)
The Philips DVP642 is a DIVX player so I assume you are saying you want to write the file as a DIVX AVI.
You still have to re-encode to add borders but in this case it will be DIVX to DIVX.
I would use VirtualDub to do this.
- Load the AVI into VD.
- Select 'File Information' and take a note of the Data Rate.
- Select 'Video' -> 'Filters' -> 'Resize'.
- Make 'New width' and 'New height' match the size of the video.
- Tick 'Expand frame amd letterbox image'.
- Click Show preview.
- Set the 'Frame width' & 'Frame height' to the desired sizes (you will probaly want to make sure that the aspect ratio stays the same as the original so that the picture doesn't distort).
- Say OK to these settings.
- Now select 'Video' -> 'Compression' and select the DIVX codec, and set the bitrate to the same (or better still a little higher than the original to compensate for the extra black areas) - do a two pass if you wish.
- Now save the resized and bordered AVI as a new file.
.. that's one way. -
thx man.. that helped,... did everything u said.. tested, i see subs.. but there are problems... it seems like sometimes the audio skips(like a fuk up cd), and the audio does no go with the guy that is talking.. its all out of line... help?? also plz more info on Compression... need more detail
did you reencode the audio? audio->full processing? or audio->direct stream copy?
ok im trying ti with full so lets see how it goes.. i'll repply back and see if it works
and oh yea can i get more help on the Compression.... u sure its DIVX codec.. or Xvid MPEG-4???
will yea i fixed the audio poblem but now i have a size problem.. it went from a avi file 178mb to a 400mb avi file?? why?? i resized it to be smaller 640x480 to 610x450..
will i cant change its size, i try the lowes sitting i can go 16k but still big file.. heres the pic of what i didn.. just tell me what to change
wil maybe i was doing it wrong.. heres another pic.. but im still getting over 200mb
One minute you are using xvid, the next divx, which is it
In any case, it is most definatley the bitrate you want to change, that and playing time are the only things that affect filesize. Open the original avi in gspot and use the bitrate it reports in there when you re-encode. -
will it doesnt matter how low i go.. its still goes over 250mb.. my avi is 170mb... even if i put 0 its still over 250mb... but thats only if i put full processing... so anyone know why??
"PS
for a forum that helps on these kind of stuff.. no one really helps"
It seems to me that a couple of people are at least trying to help you. Don't be surprised if you get even less help now after a smartass comment like that! -
Originally Posted by Vanster
You are in breach of the forum rules and are being issued with a formal warning.
/ Moderator BJ_M
stop criticising others who are trying to help you
its not their fault that you dont know how to do this
alternatively you could attempt to use tmpeg to encode as a dvd or svcd rather than xvid
mpeg2 is an easier format for noobs to use than avi as you wont have to set the codec up [i say mpeg2 as mpeg 1 vcds usually look crap]
to add black bars
setting-> advanced -> clip frame -> arange settings -> centre or centre keep aspect ratio also you can crop the picture -
Hello!
I may be missing the obvious but a 640x480 AVI video *should* play perfectly on your Philips DVD/DivX player!
640x480 is a nice standard video frame size with an aspect ratio of 4:3.
I'm wondering if this is an issue related to your Philips player / TV. If your setup is anything like mine then you can muck about with settings such as NTSC / PAL / Automatic, set 16:9 / 4:3 / Automatic / zoom etc. etc. on both the Player AND the TV. Sometimes I have to play around with these settings to get the picture right. Get some of these settings confused and you will end up with the problems I think you are seeing.
Give this a try, you never know!
AndyWork you bloody thing....
How to resize and convert MPEG-2 file so I can work with them in PrPro CS4?
By tomchook in forum Newbie / General discussionsReplies: 7Last Post: 13th Apr 2012, 11:02 -
Want to resize an avi
By janlafata in forum Video ConversionReplies: 2Last Post: 17th Aug 2009, 23:06 -
.avi to DVD + resize
By grandsire02 in forum Video ConversionReplies: 2Last Post: 9th Mar 2009, 17:28 -
resize trouble with avi.net
By g_enqui in forum DVD RippingReplies: 2Last Post: 1st Nov 2008, 14:16 -
Resize Suggestion for AVI-DVD Encode
By Soopafresh in forum Video ConversionReplies: 10Last Post: 26th Jun 2007, 11:01
