if encoding at 720x576 wats the lowest bitrate to use without blocks appearing?
It's dependent on too many things to get a specific number.Originally Posted by DarthBooker
A movie with all dialog then maybe 4000 avg 6500 peak. A lot of action and flashing lights then maybe 7000 avg. and 9800 peak.
I disagree, to an extent anyway. in low motion scenes with lots of dialog you can go much lower than 4000kbps. A talking head will look fine at 2000kbps and possibly even less. Using VBR encoding, the encoder does the maths for you. As Capmaster (sort of) said, it is the average bitrate you need to worry about if you are concerned with file size or getting max playing time of your DVDr.Originally Posted by Capmaster
Should i put average bitrate or max bitrate in 2pass encoding mode?
By tendra in forum Video ConversionReplies: 28Last Post: 11th Nov 2011, 08:38 -
Question about bitrate, spikes and Bitrate viewer
By sasuweh in forum Authoring (DVD)Replies: 3Last Post: 25th Oct 2010, 16:01 -
Using mutiple passes with lower bitrate vs single pass with high bitrate on
By jones24 in forum Newbie / General discussionsReplies: 15Last Post: 14th Aug 2009, 19:17 -
Most compatible codec, Lossless bitrate, and max bitrate
By sevenlayercookie in forum Video ConversionReplies: 2Last Post: 6th May 2009, 21:43 -
Low bitrate source to High bitrate target
By sameerdhiman in forum Newbie / General discussionsReplies: 2Last Post: 8th Nov 2008, 00:54
