A Full-Featured Suite for Today’s Digital Audio Workstation
DTS technologies deliver the highest quality audio available on the market today. With more than 280 million DTS-licensed consumer electronics products available worldwide, there’s a compelling reason for content owners and producers to be releasing DTS-encoded software for movies, music and more.
Designed for today’s digital audio workstations, the DTS Pro Series Encoder is equally at home whether you are running on a Mac or a PC. This software suite delivers the same high-quality compression algorithm that has made DTS a favorite among audiophiles.
The DTS Pro Series Encoder offers a range of encoding options to inspire and support your creativity.
PC and Mac OS X compatible
The DTS Pro Series Surround Encoder contains the full suite of renowned DTS Technologies.
• DTS Digital Surround® for 5.1 channel surround sound
• DTS-ES 6.1 discrete for enhanced surround precision – only DTS delivers a discrete center surround channel, and DTS ES content is always backward-compatible with all DTS decoders on the market
• DTS 96/24 for the highest resolution audio on DVD-Video with 5.1 discrete channels
Choice of 4 Sampling Rates
• 44.1 kHz for use on CDs
• 88.2 kHz for even higher quality on CDs
• 48 kHz for DVD-Video
• 96 kHz for the highest resolution on DVD-Video*
Choice of 3 Bit Rates
• 754 kbps for the best balance of quality when optimizing your bit budget
• 1.5 Mbps when the highest possible quality is your aim
• 1.235 Mbps for multi-channel music CDs
Choice of Configurations for Multi-Channel Audio**
• 5.1 channels – the standard for surround sound
• 6.1 channels – DTS-ES 6.1 discrete***
* Use of 96 kHz sample rate requires use of 1.5 Mbps bit rate
** Other configurations include: 2.0, 2.1, 3.0, 3.1, 4.0, 4.1, 5.0, DTS-ES matrix
*** When selecting 6.1 discrete, choose either 48 kHz or 44.1 kHz sample rate
System Requirements
Apple Computer
• Power PC G4 or higher (Dual Processor G5 recommended)
• 256 MB RAM
• 1 hard drive, 7200 RPM minimum
• 100 MB free disk space
• Greater than 20 GB recommended for audio files
• USB port for the license adapter (dongle)
• OS X version 10.2.8 or higher with Java Runtime Environment version 1.4.0 or higher
PC Computer
• Pentium 4, 1 GHz or higher (recommended)
• 256 MB RAM
• 200 MB free disk space
• Windows XP Home Edition or XP Professional (SP1)[/i]
http://www.dtsonline.com/
links on the front page"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
How i can convert the dts-es or dts-ex 6.1 into dts core 5.1
By fits79 in forum Newbie / General discussionsReplies: 18Last Post: 19th Aug 2012, 16:25 -
How i can convert dts-es to dts-core from one mkv file?
By fits79 in forum Video ConversionReplies: 3Last Post: 11th Jun 2011, 21:24 -
Convert DTS-MA to DTS with XMedia Recode?
By smackyourfupa in forum Blu-ray RippingReplies: 3Last Post: 14th Apr 2011, 08:23 -
help gettinng .m2ts with dts to play on ps3 with the dts intact. got close
By jayjay139 in forum Blu-ray RippingReplies: 0Last Post: 12th Mar 2010, 12:10 -
DTS encoded disk, output to DTS receiver using an HTPC
By ChipMcC1 in forum Media Center PC / MediaCentersReplies: 6Last Post: 18th Nov 2007, 07:06
